how to change "customer testimonial" and "video information" on default front page THEMIA PRO
Discussion in 'Themia WordPress Theme' started by javeqtech, Feb 28, 2014.
  1. javeqtech
    javeqtech New Member
    my domain is: www.tlfinancialgroup.com
    i would like to put widget instead of the"customer testimonial" and "video information" .
    where are they located?
    Thank you
    Go to the Appearance > Theme Options > Home Page Settings panel in your dashboard and put your content in the
    Testimonial Content section and Testimonial Widget section.
  3. johnpnewton
    johnpnewton New Member
    Thanks I had already done this for the Testimonial section, but how do I edit the video that is displayed.
  4. sameerwalkar
    sameerwalkar Guest
    Go to the Appearance > Theme Options > Home Page Settings panel in your dashboard and put your content in the Testimonial Widget Heading and Testimonial Widget.
    To put video you can embed iframe code in Testimonial Widget. you can also refer the below given image.
    Thanks & Regards,
    Sameer Khanwalkar
