How to change header color?
Discussion in 'Compass WordPress Theme' started by jisenberger, Aug 22, 2014.
  1. jisenberger
    jisenberger New Member
    California
    Is it possible to change the header color?
  2. Yogesh
    Yogesh Guest
    If in header you used image then we can't change header color, if you used text in header then you can change header color.
    Please provide us your website url as well as the screenshot where you facing the problem.
    That will resolve your issue.
    Yogesh Bhade
