How to change number of columns on front page
Discussion in 'ColorWay WordPress Theme' started by inkthemerwp, Dec 18, 2013.
  1. inkthemerwp
    inkthemerwp New Member
    Using the Colorways Pro theme, how would you change the number of columns under the feature image from 4 to 3 columns, or any other number like 1 or even 5?
    Would this have to be changed every time the theme was updated?
    Thx in advance.
    If you want to reduce the feature column then you can accomplish it through style custom css code but
    if you want to increase feature column then you can add the custom html code for extra feature column
    in the front-page.php file present in your theme directory.
  3. inkthemerwp
    Would you be willing to tell me what the code is, as in other examples I have seen? I am trying to change it to 3 columns.
  4. Gourav
    Paste this code in Custom CSS
    #content .one_fourth.middle.last{
    display:none;
    #content .one_fourth{
    width:29%;
