How to change "Wordpress themes with single click installation"
Discussion in 'Squirrel WordPress Theme' started by muppett1984, May 29, 2014.
  1. muppett1984
    muppett1984 Guest
    also the bit underneath that says "just a click and your website is ready to use". I have found a post on how to remove it but not how to change it.
    Thanks.
  2. muppett1984
    muppett1984 Guest
    Have found where it is. Now i need to know how i can just get rid of that space entirely, if i want nothing there. The post about it in the thread i have seen doesn't work.
  3. Piyush
    div.header-info {
  4. muppett1984
    muppett1984 Guest
    Thank you, worked a treat.
