How to create a drop-down menu in het header
Discussion in 'Dzonia WordPress Theme' started by erwin, Oct 22, 2012.
  1. erwin
    erwin New Member
    How do I create a drop-down menu in the header, next to the Home button?
    Thanks in advance for your reply.
    Erwin
    For creating dropdown all you have to do is add new pages name them (for eg. submenu 1, submenu 2)then select Menus option (Appearance > Menus) and follow instruction given in image
