How to create columns on a page layout
Discussion in 'Harrington- A WordPress Business Theme.' started by dmedia, Jun 28, 2016.
  1. dmedia
    dmedia Member
    Hi - I installed this theme to replace another. In the previous theme I was using the plugin WP Easy Columns to create 2-columns in the layout on pages. The columns are no longer working in this theme. I am getting an error message every time I try to install WP Easy Columns.
    So I tried 2 more plugins:
    Column Shortcodes By Codepress
    Columns By Konstantin Kovshenin
    Neither one will work either in this theme. They use shortcodes. But when I put in the shortcodes they appear just as text on those pages and do not format the layout into columns.
    Is there something blocking the shortcodes from working in this theme?
    Or do you have a recommendation for a plugin to format pages into columns?
    Appreciate your help greatly!
    Your Website URL:
    WordPress Username:
    Password :
  3. perlaz
    perlaz Member
    No wonder the plugin WP Easy Columns does not work properly:
    Last plugin Updated: 2 years ago
