How to delete "modules" ??
Discussion in 'General InkThemes Discussion and Feedback' started by datagram, Nov 19, 2017.
  1. datagram
    datagram New Member
    I purchased the MediCannabis template, and there is no option to remove the "testimonials", "gallery", or any of the things on the page.
  2. akbar92
    Let me know which sections you want to remove with the help of edited screenshots so that I will give you CSS codes to remove those sections.
    Looking forward to hearing from you.
    Akbar
  3. datagram
    datagram New Member
    Hi :) I would like to remove Testimonials and the "contact us" section. I cant get the form to send an email so I will just remove it
  4. akbar92
    To remove contact section, use the below code:
    .contact-wrapper {
    And to remove gallery section, use this code:
    .parallax-container {
    .gallery-wrapper {
    Do let me know if you need further assistance.
    I will be glad to assist you.
    For more help, you can explore our Support Forum, Documentation and FAQ's
    Forum Link: https://www.inkthemes.com/community
    Theme Documentation: https://www.inkthemes.com/documentation/
    FAQs Link: https://www.inkthemes.com/community/forums/frequently-asked-queries-faq.174/
    Thanks & Regards,
    Akbar
