How to display Select form custom field info on homepage
Discussion in 'GeoCraft WordPress Theme' started by kentoliver, Jun 25, 2013.
  1. kentoliver
    kentoliver Active Member
    Hey there, I am using a custom input field for one of my websites, and I am wondering how to display the information from that custom field on the homepage.
    I have successfully done this on the single listing page, by using:
    <?php if (strpos($p_price_per,'Hour') !== false) {
    echo '<span class="permonth-slash">/</span><span>hr. </span>';
    } else { echo ''; } ?>
    However on the homepage this does not work. I noticed that on the homepage to grab fields you are using something like this:
    <?php if (get_post_meta($post->ID, 'geo_address', true)): ?>
    <p class="f_post_meta"><img src="<?php echo TEMPLATEURL . '/images/location-icon.png'; ?>"/>&nbsp;<?php echo get_post_meta($post->ID, 'geo_address', true); ?></p>
    <?php endif; ?>
    I was wondering if you could give me a little php snippet that would let me load a custom select field. The custom select code being $p_price_per. with the selects I have set up being = Hour, Day, Week, Month, Year
    in short ^_^ {
    if p_price_per = 'Hour' then echo
    Just not working when I do it
    Thanks again!
  2. kentoliver
    Just a bump ^_^
    Know this is possible because you offer select, radio and other options as custom fields. Just wondering how to call them on the homepage ^_^
  3. kentoliver
    Another bump.
  4. Nitesh
    Sorry for the delay.
    You can show any of your custom field on home page where you want.
    PHP:
    <?php
    echo get_post_meta($post->ID,'meta_key',true);
    Please check image attached for reference.
  5. kentoliver
    Nitesh.
    You are going around my question. You are telling me how to grab a key.
    Which i already know because I showed you the following code in first post:
    Please RE-Read what I am asking.
    I need to display a line of code IF the string I am calling equals a selected value.
    This is important because it lets me display depending on if my user has selected a field in the input / add listing process.
    Here is what I am asking for... again:
    If custom field key is value, then echo statement. otherwise do not.
    I CAN achieve this on my listing page, but not homepage.
    This is possible by doing this:
    } else {
    echo ''; } ?>
    I do not want to simply call the field because it is not what I am looking to accomplish. As it just calls a string, which is not what is needed.
    As this way I can set up if user selected price to be by hour, then to display code with span and class opposed to just a frontend variable.
    Thanks for your time Nitesh
  6. kentoliver
  7. kentoliver
  8. Nitesh
    Hello Kent,
    PM sent.
  9. kentoliver
    Thanks, Ill stop bumping and use the convo. Talk to you later on.
  10. kentoliver
    I have found the solution. Sorry for all the posts.
    All the best,
    -Kent
