How to edit a MENU links or its url
Discussion in 'RoadFighter WordPress Theme' started by bernz, Feb 15, 2014.
  1. bernz
    bernz Guest
    Hi all,
    This may be simple to some and it was in the previous wordpress 3.0 to 3.6 isn. I am having a rough time trying to edit a MENU links or it's url. I have existing menus and would like to use them and simply change the link (url) it has to a different link or page. I am trying not to create another menu to do this and maybe I am missing something in doing this.
    Can anyone help.
    Thank you
    Ben
    Hello Ben,
    There are two types of menus.
    Page menu and custom menu. You can change url of custom menu but not of page menu.
    Create custom menu from links option and add your url there.
    Check image for reference.
    Nitesh Raghuwanshi
  3. bernz
    bernz Guest
    Thank you, found out if there are pre-existing menus that it is impossible to change that url unless it is a custom menu.
