How to edit SeaFish PRO Blogpost text preview?
Discussion in 'General InkThemes Discussion and Feedback' started by camgia, Oct 17, 2017.
  1. camgia
    camgia New Member
  2. akbar92
    That text automatically comes from the created post, whenever you create a post, the homepage recent post section automatically crawl the text from that post.
    Hope you understand this.
    Do let us know if you need further help.
    Thanks & Regards,
    Akbar
  3. camgia
    camgia New Member
    Thank you,
    but what if I modify a post ? Actually I modified the post but the text preview is still the same old one.
    How can I refresh it and get the recent post section automatically re-crawl the new text ?
    In addition, how I change the image near the post ?
  4. camgia
    camgia New Member
    Well, I figured out both of requests: for the matter of update, creating a new edited post from an old one, and deleting the old one, does the trick.
    For the matter of replacing images, I found the correct path Activating the visual preview.
    Now, I have a different problem. Suddenly, my new posts don't show anymore in the Blog post preview. 5 Posts published, only 4 visible.
  5. akbar92
    Did you set the featured picture while creating a blog post? Because if you won't set the featured image then the post will not display on the homepage.
    Do let me know if you need further help.
    Akbar
  6. camgia
    camgia New Member
    Great, problem solved.
    Lesson learned.
    Thank you !
  7. akbar92
