How to edit "Shortly about us" and "Contact us"
Discussion in 'BlackBird WordPress Theme' started by nidjo, Jan 16, 2014.
  1. nidjo
    nidjo New Member
    Hi guys, how and where can I edit "Shortly about us" and "Contact us" ad the bottom of the pages? I want to write my own "about us" and "contact us".
    Go to the Appearance > Widgets panel in your dashboard and then
    drag & drop text widget in the First Footer Widget Area and as well as in Third Footer Widget Area
    and then put your text in the content section of text widgets.
    See the image for reference.
    This will display your content in the footer widget area.
  3. nidjo
    nidjo New Member
    Piyush thanks, beautiful theme! Not the first one I've bought from you guys either, keep on the good work and thanks for your answer :)
    Piyush likes this.
  4. expertcanine
    expertcanine Guest
    Columbus, OH
    I added the Text widgets, just like you instructed above - but the paragraph content doesn't show on the webpage. The headline shows, just not the paragraph.
    NEVER MIND: FIXED IT MYSELF (Miracles Happen)
    Thin Blue Footer at very bottom: Edit under Appearance> Theme Options > Footer Settings
    Three Widget Areas above Footer: Edit under Appearance > Widgets > then follow the steps above to click and drag a Text Widget to the > FIRST WIDGET FOOTER AREA, SECONDARY WIDGET FOOTER AREA and THIRD WIDGET FOOTER AREA.
    The Social Media Widgets (Icons in Second Area): Edit under Appearance > Theme Options > Social Icons. You just enter the URL info or you can delete the # symbol, to delete the item all together.
    Hope this helps someone!
