Hi There, On my contact page search categories and archives widgets show even though I have removed them. Please let me know how to make them not show on the contact page. Thanks, Sandra The website is primestrategyinc.com
Hello, Greetings from InkThemes! Please follow the screenshot given below. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hi There, I have located the section you mention but it does not look the same and I can not find the area you want me to remove....Please advise. Thanks, Sandra This is the text that I see: <?php /** * The template for displaying Category pages * */ get_header(); ?> <!-- ----------------------------------------------- --> <!-- ---------------Blog template ------------------ --> <!-- ----------------------------------------------- --> <!----------------------Post 1--------------------------> <div class="page-top-bg"> <div class="container"> <div class="row"> <div class="brd-crm"><h1><?php printf('' . single_cat_title('', true) . ''); ?></h1></div> </div> </div> <?php if (woodpecker_get_option('woodpecker_headbg') != '') { ?> <img src="<?php echo woodpecker_get_option('woodpecker_headbg'); ?>"> <?php } else { ?> <img src="<?php echo get_template_directory_uri(); ?>/images/page-top-bg.jpg"> <?php } ?> <div class="top-bg-mask"> <?php if (woodpecker_get_option('woodpecker_headbg') != '') { ?> <img src="<?php echo woodpecker_get_option('woodpecker_headbg'); ?>"> <?php } else { ?><img src="<?php echo get_template_directory_uri(); ?>/images/page-top-bg.jpg"><?php } ?> </div> </div> <div class="container"> <div class="row"> <div class="page-post-container-wrapper"> <div class="col-lg-16 col-md-16 col-sm-16"> <!-- ----------------Category Page starts --------------------- --> <?php if (have_posts()): ?> <?php /* Since we called the_post() above, we need to * rewind the loop back to the beginning that way * we can run the loop properly, in full. */ rewind_posts(); /* Run the loop for the archives page to output the posts. * If you want to overload this in a child theme then include a file * called loop-archives.php and that will be used instead. */ ?> <?php get_template_part('loop', 'category'); ?> <nav id="nav-single"> <span class="nav-previous"> <?php next_posts_link(OLDER_POSTS); ?> </span> <span class="nav-next"> <?php previous_posts_link(NEWER_POSTS); ?> </span> </nav> <?php endif; ?> <!-- ------------------Category loop ends----------------------- --> </div> <div class="col-lg-8 col-md-8 col-sm-8"> <?php get_sidebar(); ?> </div> </div> </div> </div> <!-- -----------------------Blog template ------------------------- --> <!-- --------------- --> <!-- -FOOTER Starts- --> <!-- --------------- --> <?php get_footer(); ?>
Hello, For your information, I am using "WP-Editor" plugin to edit files. You can also download and use it from the link https://wordpress.org/plugins/wp-editor/. After activating this plugin, you will get the same screen as shown in the screenshot. Hope you will get it helpful.. Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
I am having the same issue. i would like to remove the three widgets left on my contact page, I would like to remove search, archives, and categories. I am not sure what you mean when you say "Commet-out" on your screen shot. I deleted the lines 169-171 but the widgets still show up. Please can you help. Please see http://skyshotmuskoka.ca/index.php/contact-us/
Hello, Would you please clear your cache and check after that? Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
I have cleared my cache in wordpress and in my browser and still have search, archives, and categories in the side bar. any other suggestions??? Thanks
Hello, To determine and fix the issue, we need to access your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link. Your Website URL: WordPress Username: Password : Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
