how to eliminate the social sharing buttons on posts
Discussion in 'BlogSpring WordPress Theme.' started by sandradohn, Jul 15, 2017.
  1. sandradohn
    sandradohn Member
    Hi There, Will you let me know how to eliminate the social media share buttons from posts? Thanks, Sandra
  2. akbar92
    To eliminate the social media share buttons from posts, just paste the code given below in Custom CSS section.
    .featured_post .post .post-social-link {
    Hope this helps...!
    Akbar
  3. winterbottom
    winterbottom New Member
    There is no code in Custom CSS section, when I do follow your description. Still, there are social media share buttons in my posts. Is there any other way I can remove them?
  4. akbar92
    Thanks for contacting us,
    You need to paste the below-given CSS code in the Custom CSS section:
    .post-social-link-inner.single {
    If it will not work then just paste the code into the Additional CSS section of the theme instead of Custom CSS section, Go to (Dashboard->Appearence->Customise->Additional CSS).
    Hope this helps...!
    Akbar
  5. winterbottom
    Unfortunately, there is still this "If you enjoyed this article please consider sharing it! [​IMG] [​IMG] [​IMG] [​IMG]" underneath my posts. No matter where I pasted the given code.
    Thanks for your help.
  6. akbar92
    Will you please share the page URL where the icons appear?
    So that we could assist you accordingly.
    Akbar
