how to eliminate the top menu on home page
Discussion in 'StartPoint Business One Page WordPress Theme' started by sandradohn, Aug 18, 2017.
  1. sandradohn
    sandradohn Member
    HI There, How do I remove the menu from showing on the home page? I have attached a screenshot. Thanks, Sandra
  2. sandradohn
    sandradohn Member
    here is the screenshot. thanks, Sandra
  3. akbar92
    To remove the top menu bar, just paste the code given below in Custom CSS section.
    .menu-wrapper-bg ul#menu-front {
    Hope this helps...!
    Akbar
  4. sandradohn
    sandradohn Member
    Hi There, I tried this and it did not work. I also cleared my cashe. Please advise. Thanks, Sandra
  5. akbar92
    Hello Sandra,
    Just paste the code in the Additional CSS section instead of Custom CSS section.
    (Dashboard->Appearence -> Customize -> Additional CSS)
    Hope this helps...!
    Akbar
  6. sandradohn
    sandradohn Member
    HI There, I tried this and it did not work. Please advise. Thanks, Sandra
  7. akbar92
    Hi Sandra,
    Use the below mentioned code:
        display: none !important;
    If it will still not works, just send the below-mentioned credential details at [email protected] along with the thread link.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
    Akbar
