Hi I've been using Geocraft widget category to show all listing category at my front page (using hierarchy selection). But when im start adding sub-category, i realized that between the sub-category in widget, there's a significant gap white space. How do i eliminate these white space gap? so my sub-category looks close to each other, rather than separated by these white gap. Thank you note : i'm look at the widget.php files, but not sure which code should i edit. so i made a screenshot for references. Thank you Iqbal
Hi Iqbal, Greetings from InkThemes, To remove that space, just paste the code given below in Custom CSS section. (Dashboard->GeoCraft->Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .sidebar ul li .children { list-style-type: inherit; } Hope this helps...! Thanks & Regards! Akbar InkThemes.com
