How to find ID for start page
Discussion in 'SaleJunction E-Commerce WordPress Theme' started by andreas_melin, Oct 6, 2014.
  1. andreas_melin
    andreas_melin New Member
    Dear sirs,
    I would like to put all my pages in the footer (spread over all four footer widgets). However, I can not seem to find the "home" page ID so that I can hide it. Right now "home" is written on all four footers on the top.
    I know that you can chose to make like 4 menus instead and put a customized menu in the footer, but in this case, I would prefer to know how to find the "home" page and to see its ID.
    Thank you for your time.
    Kind regards,
  2. Pramod
    Pramod Guest
    Unfortunately there is not any id or class for 'Home' .
    But you can try this to do that.
    .ddsmoothmenu li:first-child {
    background: pink !important;
    .ddsmoothmenu is just a class if you are using different class in footer use that class with dot.
    Above code is to change color you have to use below code to hide it.
    display:none !important;
    Pramod
  3. andreas_melin
    Dear Pramod,
    thank you for the quick reply. I will try your suggestion.
    How can I hide the google analytics track code on top of the page?
    I tried various versions of this without success:
    .top_trackinfo {
    any suggestions?
    All the best,
    Andreas
  4. Pramod
    Pramod Guest
    Google analytic code should not be shown on page. There is something wrong .
    Put it correctly. There is an options in theme to put it or you can directly put it in header section .
    Read instructions to use Google code in effective way.
    Pramod
  5. andreas_melin
    Ah, ok. I pasted the entire script and then it worked perfectly. I thought I just needed to put the track ID in there :oops: Thanks again guys!
