How to fully translate INFOWAY theme into French ?
Discussion in 'Infoway WordPress Theme' started by satemorej, Jun 23, 2014.
  1. satemorej
    satemorej New Member
    I have used provided .po file with POEDIT to create my fr_FR.po file.
    I translated all strings in the .po file.
    However, untranslated strings remain all through my site (for example, in contact form)
    Will you insert more terms into the default.po file in next theme release or should I hard code translation into the theme files ?
    thanks for your help.
    Jerome
    Hello Jerome,
    Please provide us a list of untranslated terms. We will definitely add them in the next version update.
    Nitesh Raghuwanshi
  3. satemorej
    Hello Nitesh
    Sorry for being away from my INFOWAY site for such a long time.
    In fact, contact page can not be translated thanks to .PO file. I would probably achieve it by editing the template-contact.php file but
    not sure it would be the best way.
    Regards
    Jerome
  4. Sobhagya
    Sobhagya Guest
    Hope Doing Good.
    It would be nice way to edit template-contact.php file for translate contact page.
  5. satemorej
