how to Go to Js > slides.min.jquery.js
Discussion in 'GoldenEagle WordPress Theme' started by raymondonline, Nov 20, 2012.
  1. raymondonline
    raymondonline New Member
    In downloaded theme, You will get zip file, Extract it, There you will get theme directory > Js > slides.min.jquery.js.
  3. raymondonline
    after i change the file, is it i should only upload and replace that single file only?
  4. Nitesh
    Yes replace that single updated file (slides.min.jquery.js).
