How to increase recent, poupler and recomnded listing?
Discussion in 'VideoCraft WordPress Theme' started by ahoque, Jun 30, 2014.
  1. ahoque
    ahoque Guest
    How to increase recent, populer and recomnded listing in the featured videos in homepage? Currently it has 3 I want to incrase to 10.
    For this open "front-page.php" file and increase value as shown in the image.
    Nitesh Raghuwanshi
  3. ahoque
    ahoque Guest
    Hello, I tried and it still lists the default number, which is 3.
  4. Gourav
    Go to front-page.php present in your theme directory and follow the instruction as shown in image given below
    Now,
    Paste this code in Custom CSS
    ul.videolist1, ul.videolist2, ul.videolist3{
    overflow-y:scroll;
    Gourav Shrivastava
  5. ahoque
    ahoque Guest
    Thank you I will try and let you know.
  6. ahoque
    ahoque Guest
    The scroll bar is truncating meaning the right side is cutting off. How can I expand the size of the feature video area on the left panel so the scroll bar is fully viewable?
  7. Gourav
    It is not possible to change the width of left panel.
    And your scroll bar issue, could you please explain your problem with the help of screenshot,where you have getting this type of issue and also share the link of your website, so that we can give you the exact solution.
    Gourav Shrivastava
  8. ahoque
    ahoque Guest
    Hello, the web site is www.nasheeds.tv and please look at the right panel for the scroll bar issue. Thank you very much for your help!
  9. Gourav
     .featured-post-desc h6.title {
    padding-right: 21px;
    ul.videolist1, ul.videolist2, ul.videolist3 {
    width: 326px;
    Gourav Shrivastava
  10. ahoque
    ahoque Guest
    Thank you, Gourav. This worked! The only thing left is that the "suggested" or "recommend" option still shows 3 video listing instead of 10 as for other options. How can I fix this?
  11. Nitesh
    Open front-page.php file and check whether you have increased value of "recommended" section or not.
    Please check image for reference.
    Nitesh Raghuwanshi
  12. ahoque
    ahoque Guest
    Hello, the "recommend" on the front page, still lists only one video, instead of 10 as it does on other menus.
  13. Yogesh
    Yogesh Guest
    Go to Video in Dashboard and Check Feature on Home Page Checkbox for each Video,
    to show in Recommend Videos as shown below in screenshot.
    Yogesh Bhade
