Hi there, I am building a website using squirrel pro, I am wanting to insert paragraph breaks in the pages I have made. If I insert breaks in the write up on each page they don't show up when I view the webpage. I have tried adding <br/> but still no luck. The text looks messy when viewed, so want some spacing in between paragraphs - any ideas would be appreciated. Thank you
Hello, This is not the issue of our theme, i know that the line break tag (i.e. <br>) are disappear when you go back to the Visual view but remain have their functionality to break the line, you can see this by clicking on the view page button underneath the title section. <br> tag works like this in all themes, even with the wordpress default theme. Or You can also break the line by using Shift + Enter button in the text editor, this will also work perfectly to break the line. Or You can use "<br class="blank" />" instead of simply "<br/>" , it will not disappear from the text editor.
