How to make slider link work
Discussion in 'ColorWay WordPress Theme' started by imagegrafx, Apr 29, 2016.
  1. imagegrafx
    imagegrafx Member
    My website www.thedancebox.net. I have set up the first two slides to click to appropriate page. I have the links set up on the theme options page>slider settings, but the slides do nothing. How do I make the slides click thru to the right pages? Thanks!
    I have checked your site and would like to tell you that you are using 3.2.3 version of the theme whereas 3.6.7 is available in the members area..
    So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members area.
    Download the ColorWay theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder colorway like colorway_new,
    Again, you would need to create a zip file of that renamed folder (say: colorway_new.zip),
    Then, activate your theme,
  3. imagegrafx
    imagegrafx Member
    I have tried to do exactly what you have told me to do. Here is what I get when I do what you've told me to do:
    Unpacking the package…
    Installing the theme…
    Destination folder already exists. /home/content/56/12061856/html/wp-content/themes/colorwaytheme/
    Theme install failed.
    I renamed my new downloaded file like you told me to (colorway_new.zip). This is the one I am trying to add new. Please advise. I need for the links to work in the slider. Thanks!
  4. imagegrafx
    imagegrafx Member
    my url is thedancebox.net. Thanks!
  5. priya
    It seems that you are doing something wrong in renaming the theme...
    Could you please send us your dashboard details at [email protected] along with this thread link and I will do it for you..?
