How to order listings by rating?
Discussion in 'GeoCraft WordPress Theme' started by keithn9, Aug 26, 2013.
  1. keithn9
    keithn9 New Member
    I was able to display the listings alphabetically as well as by the comment count but don't know how to retrieve the listings based on ratings. Is there a way to do this?
  2. keithn9
    keithn9 New Member
    As a user, I'd find that sorting a list of businesses in descending rating order highly important. This should be a default core feature in any review/rating site. Is this feature in the work by any chance? Has anyone managed to implement this feature?
  3. kentoliver
    kentoliver Active Member
    http://wordpress.org/plugins/ajax-wp-query-search-filter/
    I am in the works of testing and customizing this plugin. But it works with the theme, I am not 100% is the rating system is being held in a custom field, but it it is this plugin will help you sort the posts.
    All the best,
    -Kent
    PS:You need knowledge of editing the wordpress loop to get this to work, or how to copy the existing loop you are using and put it into the plugin.
    keithn9 likes this.
  4. keithn9
    keithn9 New Member
    Thanks Kent. I will experiment with it to see if that's what I'm looking for.
