Hi, Is there a way that one can put an Adsense codes on the theme just once and thereafter the Ad appears on post or page that I publish? for example , setting like 728 x 90 ad to appear at the middle or bottom of every post that I publish just automatically instead of doing it manually for every post or page? thanks Honory Jerome
Helo, It is not possible that the ad will appear automatically at the middle or bottom of the post when you published, But you can use the sidebar widget area to display your ad on every published post. Hope this helps...! Regards, Akbar InkThemes.com
Hello, Please follow the linked video: https://screenpresso.com/=1TlNf Thanks & Regards, Akbar InkThemes.com
