How to reduce Reduced footer_bottom height
Discussion in 'GeoCraft WordPress Theme' started by millmead2, Dec 31, 2015.
  1. millmead2
    millmead2 Guest
    How do I reduce Reduced footer_bottom height?
    Please check:
    http://uk-exports.org/
    Also, how do I remove the number "3" that appears below the top big picture on all pages?
    Thanks so much.
    Regards
    To reduce footer_bottom height, you just need to paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .footer_bottom {
        height: 30px !important;
    Note: Change the numeric value as per your requirement.
    For the second issue, i.e. to remove the number "3", paste the code given below in Custom CSS field of your dashboard.
    .top_add {
        display: none !important;
  3. millmead2
    millmead2 Guest
    As usual, thanks for your assistance.
    Best Regards.
    Your'rewelcome...:)
    We are always here to assist you..
