Hello, On the homepage, I would like to add the lead capture form widget area next to the slider - instead of underneath it. I'm guessing I need to shrink the slider area to make room for the widget area. I have read all 19 pages of posts and did not find a solution. I did find this support thread that mentions the Infoway 24 grid columns. I am guessing that I need to do the same for the slider to make room for the lead capture form / widget area and then adjust the image size accordingly. http://www.inkthemes.com/community/threads/remove-lead-capture-on-front-page.3683/ I'm really surprised that no one has asked for this before since it is important to show the lead capture / widget area at the top of the page? (so the visitors can see it right away and fill it out!) I am comfortable with FTP and editing the homepage code... If you could point me in the right direction I would be very thankful
Hello Eric, Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry.
