Hello Sanjay! You can simply remove the body background by applying below custom CSS code to the Custom CSS field under Theme Options panel Code: body { background: none!important; } This will help you to figure it out and resolve the issue(s). Warm Regards! Naveen Kolhe InkThemes.com
Okay. The background have removed, but how to remove or reduce space on it, so that the space above the header can be remove or reduce
Can you please share some edited screenshots of the concerned areas of your site? I will check and let you know the appropriate solution for the same. I look forward to hearing from you soon. Warm Regards! Naveen Kolhe InkThemes.com
