How to remove colour background and grey box from product
Discussion in 'RoadFighter WordPress Theme' started by solyom__, Mar 17, 2016.
  1. solyom__
    solyom__ New Member
    I installed commerce yesterday, and when I place a product category in a page, the theme add a horrible frame around it. also it place the products in a stair layout. I was checking the sample page with a different theme and I noticed, that road fighter theme make this automatically.
    Could you send me a css code, which turn off the automatic border and background settings?
    Here is an example for my problem:
    http://www.savememoney.ie/solar-pv-kits
    Thanks for your help!
  2. solyom__
    solyom__ New Member
    problem is solved
    I got a css code, which is works
    .fullwidth pre {
    background: none!important;
    border: none!important;
  3. priya
    Hope doing good.
    I really appreciate your efforts in exploring the things and sharing your knowledge here.
    It seems that you have resolved your issue by your own.
    Let me know if have further doubts so that I can assist you.
    solyom__ likes this.
