How to remove footer?
Discussion in 'ColorWay WordPress Theme' started by knleib, Mar 30, 2015.
  1. knleib
    knleib Member
    How do I completely remove the footer, color and text at bottom of page? This is the bit with...
    "Theme from InkThemes.com are based on P3+ Technology, giving high speed, easiness to built & power of SEO for lending trustworthiness and experience to a customer. The Themes are really one of the best we saw everywhere.
    - Neeraj Agarwal"
    Also Askimet spam blocker... Sorry for questions but I can't figure out.
  2. sameerwalkar
    sameerwalkar Guest
    To remove the above mentioned text by you. Go to Appearance>> Theme Options>>Home Page Settings>>Home Page Testimonial Description
    and put your own testimonial text. You can refer the given image as well:
    To remove akismet plugin follow the instructions mentioned in image:
    Sameer
  3. knleib
    knleib Member
    Thank you. Is there a way to completely remove the testimonial section from the homepage? I entered the code you mentioned above but the big " is still there. Thanks.
  4. sameerwalkar
    sameerwalkar Guest
    Apply and paste the code given below in Custom CSS section
    (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard that will remove the testimonial section completely.
    blockquote.home_blockquote {
    Sameer
  5. knleib
    knleib Member
    That's it. Thanks.
