How to remove "Four Column Feature" comments
Discussion in 'Traffica WordPress Theme' started by devsmum, Feb 10, 2015.
  1. devsmum
    devsmum New Member
    Hi there
    I have successfully uploaded images into the four column feature under the Homepage Feature Area. there are Feature Heading and Feature Description boxes.
    The feature Description box has the default text "Site speed is one of the few ranking that Google has officially confirmed."
    How do you remove this text please?
    Anne
  2. Yogesh
    Yogesh Guest
    Go to Appearance => Theme Options => HomePage Feature Area => Then add your description in First Feature Description, Second Feature Description and Third Feature Description.
    If you want to don't show description even default text then just press SPACE key in that input area.
    It will resolve your issue.
    Yogesh Bhade
  3. darrel
    darrel New Member
    Where do I remove/add code to stop the feature boxes from flipping? Or I would use the flip side if I could stop the text from the front of the flip showing through onto the back side of the flip.
    I would rather use the flip but I don't like the text from front showing through the back.
  4. darrel
    darrel New Member
    Figured it out I think.
    Posted this code in the Custom CSS area:
    .flip-container:hover .flipper,
    .flip-container.hover .flipper { -webkit-transform: rotateY(180deg); -moz-transform: rotateY(0deg); -o-transform: rotateY(0deg); transform: rotateY(0deg); }
  5. Naveen
    That sounds great :)
