How to remove InkThemes logo and other junk content from my home page
Discussion in 'Traffica WordPress Theme' started by catonius, Sep 1, 2015.
  1. catonius
    catonius New Member
    See attached image. I don't see how to get rid of this content or change it. I spent an hour searching for an answer. I have the pro version and I want to use it for a business site so this nonsense doesn't belong. What is it supposed to be? Much of it doesn't even make sense.
    Traffica WP theme is what I am using.
    To remove or change the content of the Inktheme Logo section:
    You can easily change or remove this section, you just have to follow the steps as mention in the video given below.
    Link of the video: http://screenpresso.com/=deeZ
    Note: for your knowledge, if you want to change the content then you just have to write down your content over there (i.e in the text field)..
    If you don't want to show anything over there then just keep that field blank as I have done in the video.
    For the Footer area:
    To change all the content of footer area, just follow the steps as mention in the video given below.
    Link of the video: http://screenpresso.com/=vHX9b
    If you want to remove that part (footer area) completely, all have to paste the CSS code given below in Custom CSS section
    .footer-container {
    Hope it will resolve your issues.
    Inkthemes.com
  3. catonius
    catonius New Member
    Thanks. If I buy full membership, can I apply the cost of single pro theme or will I lose that?
    We send you an email.
    Kindly check and reply to the same.
    Inkthemes.com
  5. brodenjstaples
    brodenjstaples New Member
    Are the links to the videos available to all. When I try to access it just says not available. I also want to remove / update this section after purchasing the pro version.
  6. nitin
    nitin Guest
    The video (is present) could be viewed by all, but as it was uploaded on a temporary cloud server, it is now expired and doesn't exist anymore.
    However, I would provide you the required assistance.
    To remove the concerned section, just paste the code given below in Custom CSS section
    .iframe_div {
    To add your own Facebook like box, just follow the steps below:-
    1. Go to https://developers.facebook.com/docs/plugins/page-plugin and generate the code for your page/website.
    2. Go to (Appearance -> Widgets) of your dashboard.
    3. From the list of available widgets, drag-and-drop the 'Text' widget to the "Home Page Sidebar Feature Widget Area".
    4. Enter both the codes here, that you have generated in step 1.
    5. Save the changes.
    Hope this helps...!
    Nitin
  7. superiortestandtag
    superiortestandtag New Member
    Hi the links above don't work can you please advise
  8. priya
    Mr. Nitin had already reply in his post that "The video (is present) could be viewed by all, but as it was uploaded on a temporary cloud server, it is now expired and doesn't exist anymore" and given all the steps to get your issue resolved..
    Kindly check his thread...
  9. oleksiy79
    oleksiy79 New Member
    Video is not available. I would like to change the text in that area. Can you help?
  10. priya
    You are kindly requested to read above post that was replied by Mr. Nitin..
    Hope you get that helpful..
  11. michaelrosment
    michaelrosment New Member
