I finally figured out how to make the other changes I needed made. It would have been helpful had you mentioned that Theme Options panel could be found in the WordPress dashboard. That was the reason I had such a hard time finding what you told me to look for. I need to know how to remove the text from the top feature description so that there's nothing in that spot. Pictures/COMPLETE instructions would be most appreciated. Thank you in advance for you attention to this matter. Sincerely, Kameko
Go to Appearance > Theme options > Top Feature settings and add paragraph tag in the Top feature description.
