How to remover header button (post your business listings)
Discussion in 'GeoCraft WordPress Theme' started by albcantor, Sep 23, 2015.
  1. albcantor
    albcantor New Member
    Can we, using the theme backoffice, remove the "Post your business listing" button located at the right upper part of the header? We are not allowing people to register listings.
    Thanks.
    .header_wrapper .header_btn {
      display: none !important;
    paullan likes this.
  3. albcantor
    Hello. That will just hide the html code from view. I rather comment the php code directly on the template. Could guide as to where it is? I would also like to hide the contact form that appears whtithn each post description (listing). No way to disable it from the back office? Thanks.
  4. albcantor
  5. priya
    Please follow the screenshot given below, to comment the PHP code directly on the template for "Post your business listing" button..
    NOTE: For your knowledge, we are using wp-editor plugin to edit the file..
    # To remove the form from the listing page, Please follow the screenshot given below.
