How to rename the sentence in the left lower corner.
Discussion in 'ColorWay WordPress Theme' started by leodepalo, Aug 30, 2017.
  1. leodepalo
    leodepalo Guest
  2. akbar92
    To change the text, go to (Dashboard->Settings->General) and remove the text from the Tagline field, just follow the attached screenshot.
    Hope this helps...!
    Akbar
  3. leodepalo
    leodepalo Guest
    Many thanks. Was really simple.
  4. akbar92
