Hi, Currently the Theme has area for HTML Banner Ad Code, for just one banner. I would like to have Rotating Banner Ads in the Header Banner and Listing Banner areas. Is there a Banner Ads Rotator plugin you have that works for this feature? Please advise
Hello, I would like to suggest you to use "Simple HTML Slider" plugin.. Here is link of the plugin, please have a look.. https://wordpress.org/plugins/simple-html-slider/ Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thank you Priyanka, With Simple HTML Slider should I just past the code or shortcode into the GeoDirectory Banner setting?
Hello, Actually you have to paste shortcode in header.php file... Here's is a screenshot of where you need to paste the code, please have a look shortcode is as follow .. Code: <?php echo do_shortcode("[shs_slider_show]"); ?> Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka, Thank you, yes this works, I appreciate your help. But I have some problem questions about it: 1) The html slider is putting a link in my header ( See Attached Image) 2) I would like the slider more over to the Right. How I can do? (See Attached Image) 3) In future when I update the Theme I will every time need to setup the shortcode into header.php. This will not be so good. Is it possible that you can add this html slider a setting option in future Theme update? Please advise.
Hello, We can resolve your above isses but for that we need to do some changes in your source code, So, please send us dashboard credentials at [email protected] and we will do it for you. Regarding your last issue... We will discuss with our developer regarding your this issue and will notify you same if possible... Thanks & Regards! Priyanka InkThemes.com
Thanks, but I think it's better to wait until your developer incorporates this great Rotating Ads feature in next theme update, because otherwise I will need to change the css and header php every time of new updates. Please let me know when this feature is fully implemented asap. Thanks,
Hello Zoro, Thanks for your suggestion.. I will discuss with our developers and will notify you ASAP.. Thanks & Regards! Priyanka InkThemes.com
Priyanka, I also suggest adding the capability to add shortcode into the banner ad settings in the options panel, also add banner options for each category as well so we can add rotating/sliding banners on all pages all from the options panel rather than having to change the source code and then having to change the source code again with every update. This issue above was from August, 3 months ago, any word on including it in an upcoming version soon? Thank you
Hello, Sorry for the gap.. Actually our developers are busy in some other implementation right now.. So whenever we will get an update from their end will notify you for sure. Hope you understand, Thanks & Regards! Priyanka InkThemes.com
