How to Set H1
Discussion in 'Local Business WordPress Theme' started by bbean44, Jul 7, 2014.
  1. bbean44
    bbean44 New Member
    When posting content into theme, how do we designate the h1 phrase?
    Thanks!
    Bean
    You can use <h1> tag in the text editor for this.
    For example: Put your text with in the heading tag like this.
    <h1>Enter Your Header Text Here</h1>
    For more detail see the link given below
    http://www.w3schools.com/tags/tag_hn.asp
  3. bbean44
    bbean44 New Member
    When i check the h1 tags for this site http://katyacrepairpros.com, it shows h1's for all of this : Call (281) 393-7343 or Leave A Message Here
    Ac Repair Katy Tx
    Katy AC Repair Pros - The Best AC Repair and Replacement You Can Find When you live in a hot city, it can be very frustrating if your HVAC design decides to break down in the middle of the night ...
    I just want "ac repair katy tx" not all of this other stuff, how do i keep all the other phrases out of h1?
  4. bbean44
    bbean44 New Member
    Also, i put h1 tags around "ac repair katy tx" not the other phrases.
  5. Piyush
    Go to the Apearance > Theme options > HomePage Feature Area of your dashboard and paste the text given below in the Left Feature Description section.
    <h1>Ac Repair Katy Tx</h1>
    Katy AC Repair Pros - The Best AC Repair and Replacement You Can Find<br>
    <br>
    When you live in a hot city, it can be very frustrating if your HVAC design decides to break down in the middle of the night or when you need it the most. Almost every person is used to regulate room temperature because of a high quality comfort air system. Therefore, if your HVAC is not working properly, you may find it difficult to sleep at night. Even passing one day without your HVAC can be quite challenging for some people.<br>
    <br>
    Unfortunately, HVAC systems are quite expensive and complicated. Therefore, people who don’t have sufficient knowledge to repair them properly should hire a professional HVAC repair company. Without proper knowledge and skills, you should never try to tamper with the system. You may come across DIY tips on the internet. <br>
    <br>
    However, it can be dangerous and costly to try and repair your HVAC system on your own. You need professional help and Katy AC Repair Pros will be your best choice for AC repair and replacement. <br>
    <br>
    Katy AC Repair Pros - HVAC Repair Services <br>
    <br>
    Regular System Checks - Our HVAC repair services include regular system checks and repairs. These include : <br>
    <br>
    ● Checking shut-off valves for any kind of leaks. <br>
    <br>
    ● Bleeding hot water system radiators. <br>
    <br>
    ● Cleaning vents and heating registers to clear any dirt, dust and pet hair. <br>
    <br>
    ● Providing other services and tips to keep your HVAC system in perfect shape. <br>
    <br>
    Besides regular system checks, we also provide maintenance services and filter checks. Our ac repair services include every task to fix all kinds of issues with your rurnace and heater system. We are at your service 24/7. If you come across an emergency, you just need to call us, and we will send one of our skilled technicians promptly. For all kinds of AC repair and replacement services, we will be your best choice. <br>
    <br>
    Why Choose Katy AC Repair Pros?<br>
    <br>
    Katy AC Repair Pros has been providing high-quality HVAC repair services for a very long time. During this period, we have been able to acquire the trust, respect and loyalty of all our customers. Due to our rich experience and expertise, we are able to efficiently handle all kinds of repair issues related to your ac system. We are proud of the fact that our customers have used our services for a long time and keep appreciating us with their trust and respect. <br>
    <br>
    In our years of experience, we have realized the importance of AC repair and replacement. We understand that you invested in an HVAC system because you wanted to be stress free in all kinds of weather. Therefore, our  repair services will not only make sure that your HVAC system works properly in current weather, but also keeps your room temperature perfect when the season changes. <br>
    <br>
    As mentioned above, we provide a wide range of services. Therefore, we can keep your HVAC system in perfect shape. We only employ well-trained technicians to offer air conditioning repair services at affordable prices. Our technicians use latest equipment to manage all kinds of problems related to your HVAC system. <br>
    <br>
    We even follow up with our customers to make sure they don’t experience any problems in future. If you want to hire ac repair services at affordable prices, Katy AC Repair Pros will be your best choice. You can completely rely on us for top-notch air conditioner repair services. <br>
    <br>
    We currently service Katy Texas and these zip codes: 77449, 77450, 77491, 77492, 77493, and 77494.
  6. bbean44
    bbean44 New Member
    Thank you for your help. Last question, when i use a h1 detection site, it still shows the text above the lead capture box as a h1 as well as the part we have tagged. I do not want the phrases by lead captcha box as h1's, how do we fix that.
    And do we have a meta descroption box for the mainpage? I can use yoast for the interior pages or posts, but not sure for mainpage.
    http://forkliftrentalhouston.org
    These are the two sites i am working on that have h1 issue
