Hello I want to translate some text of the inkmemberin french, particulary thus " you must be a member to access this content, buy the package below to access the entire content' also the ' checkout' could you indicate me how to procee ? also the registration form. how to proceed? Thanks
Hello, It is not possible to change this text simply because it is an image not a text, If you want to change text then, Go to images directory present in your inkmember plugin directory and replace your image with present content-lock.png image or edit it. The name of image is "content-lock.png" Note:- Use same name for your edited image and remove the current image.
