how to translate....?
Discussion in 'VideoCraft WordPress Theme' started by dejannovakovic, Jul 23, 2014.
  1. dejannovakovic
    dejannovakovic New Member
    Hi, I am using this theme for a german project.
    I cant find a way to translate the 3 areas marked in this screenshot
    http://screencast.com/t/SARsm7z4hvsD
    I hope someone can give me a hint / explanation
    how to translate these!
    (Do I need to edit in the them editor? Or via FTP? Where do I need to change the translation? Is it conveniant to build a child theme before translating?)
    Thank you in advance for your help, and greetings from Vienna / Austria :)
    1. For translating "Add Video "
    Go to functions > define_strings.php prsent in your theme directory and follow the instruction as shown in image given below
    2. For translating "Add Video "
    Go to functions > inkthemes-functions.php present in your theme directory and follow the instruction as shown in image given below
    3. For translating "tabs "
    Go to front-page.php present in your theme directory and follow the instruction as shown in image given below
    Gourav Shrivastava
  3. dejannovakovic
    Thank you! Worked perfectly!
    I guess when the theme gets an update I would have to redo these changes, is that correct?
  4. Gourav
    You can add your customized .php files and css code in the child theme directory.
    Child theme will work for files which are in parent directory.
    Please follow the link given below
    http://www.inkthemes.com/wordpress-child-theme/02/
    I hope it will help you.
    Gourav Shrivastava
