How can I translate the listing page? Concern is numbers 1, 2 and 3, ' enter listing details and 'listing title, 'Enter listing title' and button 'Set address on Map'. Thanks for your help.
More translation issues, see screenprints below. View attachment 5959 How can I translate the 'Search', 'Location' and 'Search Listing' as well as the 'Sign in and 'Add Listing' links that appears on every? How to translate everything here on the contact page; 'Contact Us', 'Search', Contact form entries... ? Thanks.
Hello, Following tutorial link will help you to translate those text. http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/01/# It will resolve your issue. Thanks & Regards Yogesh Bhade
Hi Yogesh. That plugin doesn't help, I don't want visitors to be able to choose translations in their own language, my site is not international. I just need to translate the theme from English into Ducth. Could you help me find the right page.php where I can make the translation for the contact form and add/submit listings and the 'Search', 'Location' and 'Search Listing' as well as the 'Sign in and 'Add Listing' links that appears on every page? pls see the examples above.
Hello, You will find those words in following files so change that words in following file according to your language. 1. install.php ( in this file you can change post title in your language. 'post_title' => __('Contact Us', THEME_SLUG), ) 2. template_path.php 3. listing_type_lang.php 4. controls_path.php It will resolve your issue. Thanks & Regards Yogesh Bhade
Sorry this is getting beyond my reach. Apart from install.php, I have no idea where to find those files.
Hello, You will find above file in library folder. 1. geocrafttheme-v2\library\text_domains\template_path.php 2. geocrafttheme-v2\library\controls\custom_post_typelisting_type_lang.php 3. geocrafttheme-v2\library\text_domainscontrols_path.php It will resolve your issue. Thanks & Regards Yogesh Bhade
