How to use membership plugins & options in ClassiCraft to add to Roadfighter
Discussion in 'RoadFighter WordPress Theme' started by millmead2, Nov 28, 2015.
  1. millmead2
    millmead2 Guest
    I have a wordpress business site http://uk-exports.org and I will like normal FULL SECURE registration and the option to use social network registration. I would like to have 2 different sections for buyers and sellers. Each buyer or seller would have their own "My Dashboard" and "Login/Logout" as in this website http://dealshaven.com/ (after you register)
    In my "My Dashboard" they will be able to show all the details of their company and be able to upload several pictures and documents about their company and be able to update all their information including pictures and documents. All these information will only be seen by the admin (buyer and sellers can not communicate directly) and a notification by email will be posted to the admin's email address wherever there is a new activity/update. It will be a non-paying website. There will be different categories of products that each buyer or seller will choose when registering with the option of choosing multiple categories. All the info should be searchable by the admin. And other things that you recommend, etc, etc.
    How can I use the membership plugins and options in the ClassiCraft theme to add to Roadfighter theme?
    Kindly write back asap.
    Regards.
    Sorry I am little bit confused with your issue,
    Could you please explain it a bit more so that we can assist you accordingly?
  3. millmead2
    millmead2 Guest
    I am building a new wordpress website with Inktheme's Roadfighter. I need to add a membership register and directory to the theme as explained above but I need plugins as recommended by you. Which ones do you recommend or how can I use the membership plugins and options in the ClassiCraft theme (http://dealshaven.com ) to add to my Roadfighter theme ( http://uk-exports.org )? Thanks.
  4. millmead2
    millmead2 Guest
    Kindly help.
    Still waiting for an answer.
    Thanks.
  5. priya
    I would like to suggest you to use InkMember plugin with your RoadFighter theme.
    And let me tell you that ClassiCraft theme is totally different theme with its advanced functionality, so you can't use membership plugins and options in the ClassiCraft theme to add to your Roadfighter theme
    Hope you will get my point.
  6. millmead2
    millmead2 Guest
    Thanks for your advise.
