hyperlink is not working on homepage post
Discussion in 'BlackWell-WordPress Business Theme.' started by hitechpanda, Feb 17, 2017.
  1. hitechpanda
    hitechpanda Member
    I inserted a hyperlink on the first paragraph of a post but this is not shows up on homepage.
    Please assist
  2. Naveen
    Thank you for contacting us,
    I am afraid to say that, I was unable to locate the area in the theme...
    It would be better for us to understand your query with the help of edited screenshot.
    Naveen Kolhe
  3. hitechpanda
    hitechpanda Member
  4. nitin
    nitin Guest
    I got your concern.
    To determine and fix the issue, we need access to your dashboard.
    Your Website URL:
    WordPress Username:
    Password :
    We will try to fix the issue ASAP.
    Nitin
