I bought a theme. It shows up in Control Panel, but I can't download it.
Discussion in 'InkThemes-Support Working Hours' started by ravisangar, Mar 13, 2017.
  1. ravisangar
    ravisangar New Member
    I bought a theme and it shows up under My Account.
    However, it is not a downloadable link.
    Also, I didn't get any link to download it.
  2. Naveen
    Hello RaviSangar,
    We have got your concern and would like to inform you that, we are checking your account and will assign you the correct zip file there.
    Your patience and cooperation would be appreciated.
    Warm Regards!
    Naveen Kolhe
  3. Naveen
    I am glad to inform you that- Your issue has been fixed, Kindly check your member's account, you will find the correct zip there.
    Also, check your email, we have sent you new credentials to access your account.
    Warm Regards!
    Naveen Kolhe
  4. flowtechnology
    flowtechnology New Member
    This exact same thing is happening to me with the Excursion Service theme and I am currenly in a meeting. Can I have this resolved as soon as possible please
  5. Naveen
    I have checked your account and the zip file is there please check: https://screenpresso.com/=bzChb
    Warm Regards!
    Naveen Kolhe
