Attached is a screen shot. I have assigned ads to certain categories. It will not allow me to click on any of the category names in red on the left. It will allow me to click on the same category names on the right. For example, if you click on "advanced economic models" on the left….nothing happens. If I click on "advanced economic models" on the right then it does allow this. =============================================================== I have 2 goals 1. For every category on the left to be clickable. Why can I not click on the categories with the red font on the left? 2. Within each category, how do I add an area that says "post an ad in this category"
Hello, 1. Create sub categories under those categories, It will work fine. For adding sub categories, Just create the category and in "Parent" option, select parent category for that sub category. Please check the demo, It will show you how its looks after creating sub categories under the parent category. http://www.inkthemes.com/previews/?demo_id=42 2. Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. Thanks & Regards Gourav Shrivastava
Thank You…. I will begin making sub categories. Must they all have sub categories? Is there a way to make some clickable without subcategories?
Hello, Unfortunately there isn't a way to do that with our theme unless you custom code something up. Sorry. Thanks & Regards Gourav Shrivastava
