I can't get widget Script to work in Laundry Theme
Discussion in 'InkThemes-Support Working Hours' started by royrev, Jun 11, 2021.
  1. royrev
    royrev New Member
    New Paltz, NY
    I have this really cool software that creates video and voice messaging widgets. When you visit this page you will see the voice messaging widget button on the bottom right. https://whymobilesolutions.groovepages.com/30daytrial/
    I can not get the script code to work on my client's site: http://midhudsonlaundry.com/.
    I tried installing a couple of header/footer script plugins but no good.
    How can I get this script or any script to work on the Laundry Theme and all Ink Themes?
  2. shemaela21
    shemaela21 Guest Staff Member
    Thanks for reaching out to us,
    You will need to insert the plugin's shortcode in the header code to display the plugin's functionality in the header area.
    And to display the plugin's functionality in the footer area just add the shortcode in the footer widget area.
    I hope this will help you, let us know in case of furthermore queries we will be happy to help you.
    Shemaela
  3. royrev
    royrev New Member
    New Paltz, NY
    I don't understand creating a shortcode. Can you provide me with a video or screenshot on how to do this?
  4. shemaela21
    Warm Wishes From InkThemes,
    Kindly send the below-mentioned credential details to [email protected].
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will first check which plugin you are using, we will then assist you further.
    Shemaela
