My page is evojet.ro I have the following problems: How can I place on each page meta tags (title, descriptions, keywords)? I tried the plugin WP SEO Meta but it change the title of the first page with the title last item in the category Blog. How do to apply header tags (H1, H2, H3 etc)? On the first page appearing 10 H1 tags and must be maximum 1 Fail to put Alt attribute to images. How to put Alt attribute to image on first page slider
To speed up page, I received next recomandations: Eliminate render-blocking JavaScript and CSS in above-the-fold content Your page has 12 blocking script resources and 13 blocking CSS resources. This causes a delay in rendering your page. None of the above-the-fold content on your page could be rendered without waiting for the following resources to load. Try to defer or asynchronously load blocking resources, or inline the critical portions of those resources directly in the HTML. Remove render-blocking JavaScript: http://evojet.ro/wp-includes/js/jquery/jquery.js?ver=1.11.3 http://evojet.ro/wp-includes/js/jquery/jquery-migrate.min.js?ver=1.2.1 http://evojet.ro/wp-content/themes/startpointtheme/js/superfish.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/bootstrap.min.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/jquery.mmenu.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/jquery.singlePageNav.min.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/modernizr.min.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/jquery.flexslider.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/lightbox-2.6.min.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/jquery.imagesloaded.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/jquery.wookmark.js?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/js/custom.js?ver=4.3.1 Optimize CSS Delivery of the following: ttp://evojet.ro/wp-content/themes/startpointtheme/style.css http://evojet.ro/wp-content/themes/startpointtheme/css/bootstrap.min.css http://evojet.ro/wp-content/themes/startpointtheme/css/jquery.bxslider.css http://evojet.ro/wp-content/themes/startpointtheme/css/mmenu.css http://evojet.ro/wp-content/themes/startpointtheme/css/superfish.css http://evojet.ro/wp-content/themes/startpointtheme/fonts/fonts.css http://evojet.ro/wp-content/themes/startpointtheme/css/ie-only.css http://evojet.ro/wp-content/themes/startpointtheme/css/font-awesome.min.css http://evojet.ro/wp-content/themes/startpointtheme/css/lightbox.css http://evojet.ro/wp-content/themes/startpointtheme/css/bootstrap-theme.css http://evojet.ro/wp-content/themes/startpointtheme/css/color/dark-green.css?ver=4.3.1 http://evojet.ro/wp-content/themes/startpointtheme/css/shortcode.css?ver=4.3.1 http://evojet.ro/wp-content/plugins/contact-form-7/includes/css/styles.css?ver=4.3 How to make this?
Hello, Greetings from InkThemes! I would like to suggest you to use "Better WordPress Minify" plugin in your dashboard as it allows you to combine and minify your CSS and JS files to improve page load time. And also set standard size of all the images as mentioned in Theme Options panel of the dashboard (Appearance=>Theme Option). Here, I am providing you link of the "Better WordPress Minify" plugin, please have a look: https://wordpress.org/plugins/bwp-minify/ Here is another plugin and link which may help you to resolve your issue: W3 Total Cache Plugin: https://wordpress.org/plugins/w3-total-cache/ Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
I will try this plugin. Please answer to my first post. It is very important: How can I place on each page meta tags (title, descriptions, keywords)? How do to apply header tags (H1, H2, H3 etc)? On the first page appearing 10 H1 tags and must be maximum 1 Fail to put Alt attribute to images. How to put Alt attribute to image on first page slider
Hello, I would like to suggest you to use "YOAST SEO" plugin regarding your first issue.. Here is link of the plugin: https://wordpress.org/plugins/wordpress-seo/ Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
It does not work your solution. On the fist page, with Yoast can not change the header tags (H1, H2, H3 etc) and I can not to put Alt attribute to images. How to put Alt attribute to image on first page slide. From what I see this theme is not "SEO friendly"
Hello, To change the header tag, I would like to inform you that there would be requirement of source code customization in the theme. To put Alt attribute to your image, You can easily do it from the media field of your dashboard. Please follow the screenshot given below. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
It is not possible for pictures on the first page. These pictures (for example Pictures of slider) do not appear in the media field of dashboard.
Hello, It will be possible when you follow all the steps as mention below. 1) Upload your image in media field of your dashboard. 2) Click on that media image, you will get a URL link over there. 3) Just copy that link and paste in slider image box from Theme Option panel of your dashboard. With above steps, you will get your image in the media field and as a slider image as well. After that, you can easily set alt text for the images. Hope you will find it helpful. Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hello, Sorry to learn this.. Let me check this at our end and will notify you the same.. Your patience will be appreciated, Thanks & Regards! Priyanka InkThemes.com
Hello, You would be glad to know that we are going to implement it in our next update and will notify you the same. Your patience will be appreciated, Thanks & Regards! Priyanka InkThemes.com
Hello, You will get the updated version within 3 or 4 days.. Thanks & Regards! Priyanka InkThemes.com
Hello Ulmanu, You would be glad to know that we have updated the latest version in the members area as per my above words.. So you can get your updated version from there... Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
