Icon selector not working
Discussion in 'One Page Pro WordPress Theme' started by brainstok, May 21, 2016.
  1. brainstok
    brainstok New Member
    Hi InkThemes
    When I want to select a new icon in either Black Stribe Top Bar or for the Service sections the template will not acccept my selection. It seems to be blocked. Any advice?
    BR,
    Carl E.
  3. shailupreti
    shailupreti New Member
  4. nitin
    nitin Guest
    I just checked the things form our end and such there is no issue with the theme.
    However, if you are not able to select the icons, just send your website WordPress login details at [email protected] along with the thread link.
    Your Website URL:
    WordPress Username:
    Password :
    Also, please provide us some edited screenshot of your requirements.
    We will do it for you.
    Nitin
  5. evanjf92
    evanjf92 New Member
    FLORIDA
    I am also having this same issue, when I go to select the icon that I want to use in the services page it is not allowing me to make a selection. I wanted to know if this would be possible to fix this without giving you my login info because I am in the middle of building out the website for a different host. Any help you can provide would be much appreciated, I am working on this site to obtain a job promotion and I would really like this issue to be fixed considering I purchased it.
  6. priya
    Would you please deactivating all plugins to see if this resolves the problem. If this works, re-activate the plugins one by one until you find the problematic plugin(s).
  7. evanjf92
    evanjf92 New Member
    FLORIDA
    I believe I found a fix for this issue, it is some-what of a strange fix but I can confirm it works I've tried it multiple times please give the steps below a try:
    1. Select and activate the non-Pro edition theme for OnePage.
    2. Click Appearance
    3. Then Click Customize
    3. Select Services Section from the Customize screen
    4. Type in the code for your desired icon - I used FontAwesome so I typed in: fa fa-shield
    5. Select Save & Publish at the top of the Customize screen
    6. Navigate back to the WordPress Dashboard.
    7. Click Appearance
    8. Select and activate the Pro edition theme for OnePage
    9. Navigate back to the Customize screen
    10. Select Services Section from the Customize screen
    11. You should now have the ability to change your icons via the drop-down box which contains all of the icon thumbnails.
    If this trick worked for you please leave a reply!
    Thank You!
  8. priya
    Great..!!!
    We will surely try this and let you know..
