Icons not displaying
Discussion in 'Traffica WordPress Theme' started by hoffmanmillerads, Oct 10, 2018.
  1. hoffmanmillerads
    hoffmanmillerads New Member
    I am having issues getting the icon to display for the 4 column feature. It is just showing a blank space.
    Tried the format font awesome gave:
    <i class="fas fa-mortar-pestle"></i>
    And tried this format: (no quotes, as the example shows in the inkthemes config)
    <i class=fas fa-mortar-pestle></i>
    Same result in both places. I have tried in multiple browsers, no luck.
    Thanks.
  2. akbar92
    Greeting from InkThemes,
    Just paste this code only fas fa-mortar-pestle.
    If the problem still persists then share the WordPress credentials of your website at [email protected] along with the thread link.
    Akbar
  3. hoffmanmillerads
    that just displayed the text. I have emailed the address.
  4. akbar92
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
    Akbar
  5. hoffmanmillerads
    it looks like you got in there but only 2 of the 4 are displaying properly.
  6. hoffmanmillerads
    Any update on this? I still only have two icons displaying properly.
  7. akbar92
    We are working on the issue.
    As we are done we will get back to you soon with a positive response.
    Akbar
  8. hoffmanmillerads
    Great, thank you.
  9. akbar92
    Hello Joseph,
    I am glad to inform you that your issue has been resolved.
    Kindly view it and inform us the same.
    Akbar
  10. hoffmanmillerads
    They are displaying, which is great.
    However...
    1. the first 3 (going left to right) are aligned to the left and not centered in the circle.
    2. now the social icon is not displaying properly at the foot of the page.
    Thanks!
  11. akbar92
    Hello Joseph,
    I have done the required changes, kindly view them on your website.
    Now all the social icons are visible and I have also added a new social icon "Instagram".
    If you need further help then do let us know, we are always there to help you.
    Akbar
