Icons when uploading images
Discussion in 'ClassiCraft WordPress Theme' started by alnaami, Dec 13, 2013.
  1. M5LASTER
    M5LASTER Member
    Hi there,
    When the user uploads an image to an ad the delete icons don't look right. Please take a look at the image and tell me what's wrong what that and how to fix it.
    Thanks in advance,
    Mike
  3. M5LASTER
    M5LASTER Member
    Hi Piyush,
    This is happening on firefox and chrome. I attached images from IE, firefox, and chrome. Please see how they are displayed in all of them.
    Mike
  4. Piyush
  5. M5LASTER
    M5LASTER Member
  6. Piyush
    This issue maybe because of plugin. So please deactivate all plugins to see if this resolves the problem? If this works,
    re-activate the plugins one by one until you find the problematic plugin(s).
    I hope this will solve your issue.
  7. M5LASTER
    M5LASTER Member
    Hi Piyush,
    I tried what you suggested and found out the "Sidebar & Widget Manager" plugin is causing the issue. This seems to be the most important plugin for the site. Is there a away to fix this instead of deactivating the plugin?
    Mike
  8. Gourav
    Our theme is compatible with almost all the plugin but there are multiple plugins available in WordPress therefore it is not possible to check every plugin with the theme, You can also search the alternative of that plugin from WordPress.org
    or
    Please contact to plugin related support forum, They will provide solution for that.
