IE 8 and below Menu behind Slider
Discussion in 'BizWay WordPress Theme' started by lyynx, Jan 19, 2013.
  1. lyynx
    lyynx Guest
    Hello, I have run into many issues with the BizWay Pro theme compatability with Internet Explorer 8 and prior versions. Although I have been able to fix most, I am still having an issue where the dropdown menu is behind the image slider. This can easily be duplicated by going to bizway theme in IE 9 and clicking compatability mode. You will notice the dropdown is behind the image slider. There is also an issue with the slider showing all images, if you are having that issue, just use the custom styling in the theme options and make sure that overflow:hidden is set for the class of the slider.
    Any help with the menu is greatly appreciated as soon as possible as I am holding back a site go live just becuase of this.
    Support mail sent.
