IFrame on contact form does not work?
Discussion in 'One Page Pro WordPress Theme' started by lrepton, Apr 24, 2016.
  1. lrepton
    lrepton Member
    Your Website URL:
    WordPress Username:
    Password :
  3. lrepton
    lrepton Member
    ok
  4. lrepton
    lrepton Member
    I followed this video you sent and it still does not work. Please advise.
  5. lrepton
    lrepton Member
    When I delete the iFrame code, it shows your original map... see image google-map-empty.png
  6. priya
    As I have noticed in your first screenshot that you haven't entered right iframe code in contact box...
    Kindly rewatch the video (which I sent you via email earlier)...
    If you want to remove map completely, you just need to keep blank space in the box as I have done in your site right now..
  7. franciscosamuel
    franciscosamuel New Member
    iframe still not working ... when i enter the iframe WP "stalls" and doesn't save any information going forward.
    can you please help?
    francisco
  8. Naveen
    As I can see, you are not pasting the proper iframe Google Map code there, it must be in <iframe></iframe> tag.
    Please get the same code from the Google Map and paste it there, This will resolve your issue,
    Warm Regards!
    Naveen Kolhe
