Image appear on mouse hover and click
Discussion in 'RoadFighter WordPress Theme' started by deveshd, Jun 26, 2013.
  1. deveshd
    deveshd Member
    It is not possible to do so with this theme, But possible solution is given below
    Paste this code in Custom CSS
    #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li a:hover {
    background: url(Enter your image address here) top center no-repeat;
  3. deveshd
    deveshd Member
    didn't work as the image is being put in the navigation and not on top... See screenshot below
  4. Piyush
    Unfortunately there isn't a way to do that with our theme and Gourav has already told you in the previous post that "It is not possible to do so with this theme, But possible solution is given below" .
    You can display the image only in the background of menu button, It is not possible to show the image above the menu button when hover the menu.
